UOA results in. Bearings on this engine (Both rod and main) are aluminum. The cam rides on the head, and has no bearing, Head is aluminum. Copper went up to 8ppm this time.
Iron 10ppm below average. Metal flakes are silver/grey in color and magnetic so not copper.
I don't know. Given the fact that its not making and noise, id wager that this metal is left over from the timing chain failure previously. Id think that if there were a issue, iron would be higher.
Anyone know where the copper could be coming from? Maybe a crankshaft thrust bearing?
Most likely bearings/sleeve..like I previously said. Your rig does have almost 250k miles so it's not exactly like bearing failure would be unheard of.
From the link below...
"Copper is a component of Bronze and Brass which are used in transmissions, shifters, worm gears, bearings, sleeves, and other areas to help reduce wear. Many crankshaft and camshaft bearings have a bronze layer just below the lead/tin bearing overlay.
Potential sources of copper in UOA
![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/09/full-85545-36287-fetch.png)
