edyvw
$50 site donor 2026
That depends on the dealership and their willingness to push it, but for example, some BMW dealerships are going to code SPBR even on E90 models. Now, the dealership won't do some monkey business that is not an approved procedure. That is not at question here.What I wrote was that with a good aftermarket scanner they will be able to do diagnostic. They might be able to provide valuable guidance. And that diagnosing an issue doesn't mean they'll be able, or willing, to repair it. I don't see a tire shop in their right mind spending labor on dropping engines and chasing German-speaking gremlins when they can change tires for the same labor rate.
Not that they can't. That they won't. Virginizing used modules to fit, vs installing new ones, etc.
The first google search I did on Autel + BMW returns "Replicates capabilities of BMW ISTA-D and ISTA-P systems for coding, programming, and diagnostics" on the very first result on top of the page. Not sure what Autel your guy has. Now, does every Autel has every car module loaded ? Don't know.
As for ProTool - not here to argue. It will not do flashing, will do diagnostic and coding, which is already quite ahead of what a tire shop or a brake shop might need. I haven't dug deep enough into mine to check if it does ABS purges - I know it does have a whole ABS sub-menu.
I agree
Sure.
Autel might say whatever it wants, but it is designed to replicate, which does not mean it will do it exactly as it is written in the BMW software. Idk what Autel model he has, but it is one well above $1,000. I have Innova that also says it replicates stuff, but it does not replicate the way BMW software works. Autel will, for example, purge your brakes in the same order as ISTA. However, ISTA will command you when to press the brakes and for how long while purging valves. You won't be able to code stuff with Autel the way you can do with ISTA. For example, Autel won't do VO or SPBR. ProTool, for example, will do VO, but after you change on E90 VO to SPBR, you still have to code it in ISTA P, and neither ProTool nor Autel has that. That is what I have tried with ISTA and other OBD tools, including ProTool. Then you have numerous other functions.
Then we come to network and support, which tire shops won't have.
