However this article explains why a filter in the vertical position does not need a ADBV. In fact, some filter don't have a ADBV because of the position of the filter requirement on certain engines. Here's the link.
http://en.filtron.eu/site.php/site/menu?cat=79
They don't talk about when the filter is mounted vertically (base up) ABOVE the sump's oil level. If the filter is mounted above the oil level in the sump, any oil above that level will try to drain back to the sump due to gravity (ie, 'head pressure'). So even a filter that is vertical with base up still needs and ADBV.
No it won't. They didn't offer that explanation because it's not relevant.
Basic physics says it will. Whoever wrote that blurb you so much believe don't know the whole story. BOF's friend had a filter with a leaky ADBV. No other reason why since other filters didn't behave the same as this one when it was removed.
Originally Posted By: BlueOvalFitter
My friend changed the oil and filter on my F150 this AM. When he went to remove the oil filter (MC-FL400S) very little oil came out of the nipple and/or filter (less than an 1/8 of a cup). At every OCI quite a bit of oil comes out as soon as the seal is broke from the oil filter mounting base. I have never seen this happen before.
Sometimes friends opinions can be wrong. It's called an "Anti Drain Back Valve" Oil doesn't Drain uphill in engines. Some siphoning can ocure, but not from the filter. Notice It's not "Anti Siphon Back Valve". Cartridge filters prove that.
