I'm currently running Idemitsu EcoMedalist Dexos spec in mine. Seemed a good middle ground between the expensive mega-moly oil and your standard off the shelf oil. Still a lot of moly (400 PPM or so) but cheaper and with some better characteristics in a few areas, most notably NOACK, which is good at 11 for the dexos, and very bad at 14 for the Advanced Moly. I've also given way more thought to this than is probably necessary, and you'll be fine with any full synthetic 0W20.
That said, with these cars the bigger issue is probably the filter. Run Mazda OEM if you want to be sure, but other than that Wix 57002s are specifically for the Skyactiv engine, along with a Mobil 1 filter (M1-1800A? Look it up.) The differences may not be huge, but there's a reason why companies like Wix would bother designing a new filter just for this specific engine.
