Master main water shutoff in home built inside pedestal?
There's normally one where the water line enters your house besides the street shut off
The street shutoff is usually owned by the local govt and after that is your responsibility.
(mine is curbside)
Thats definitely not the main shutoff for the house which should be inside.
(mine is curbside)
My money is the main shutoff is in the inside of the pedestal. The pedestal is closest point to the street water main, and is where the water softener and hot water heater are.
Just not sure I want to open up the pedestal now. Lots of honey do projects, I spent four hours starting at 2am working on the fleck water softener this morning.
Are there water lines exiting the pedestal? Where does the water enter the house?
The street cover has a lock and needs a key to remove. I will be buying one of the cover keys.
Town came out and turned off the water. The tool the use to turn off the water was about a six foot long t handle.
The town was really good about coming out and shutting off the water, and then returned to turn the water back on.
You can purchase that tool at Home Depot or Lowes. I always turn the water off at the street when going on vacation...very easy to do...
  • Like
Reactions: GON
Is your softener plumbed with a bypass valve that also has an off position available? Assuming hot and cold are softened.
Yes, hot and cold are softened, but not outside water. Turning off the softener supply doesn't shut off outside water.
Speaking on water softener. House intermittently has no inside water, apparently after a water softener recharge. Spent the early morning hours the last two days tearing apart a Fleck controller.
What I suspect the no water flow after regeneration is the town is adding chlorine to the water and the chlorine is reacting with the resin, not allowing water to pass through the resin.......... always something..........
Softener should be going into bypass when doing a regeneration. Chlorine will not plug the resin bed temporarily.
Sounds like an issue in the softeners valve head.
I read Terry Love's plumbing forum, which has an excellent database on softener issues. This is where I learned about the chlorine from municipal water impacting the softener resin, thus restricting water flow through the resin. Softener does go into bypass during regeneration.
Here is one of many threads on the subject. One way to address chlorine in the municipal water is to change the resin formulation:
https://terrylove.com/forums/index.php?threads/8-or-10-resin.112133/#post-788668
