Originally Posted By: c3po
Originally Posted By: Russell
does MMO offer upper cylinder lubrication? Seems it does.
For one thing, I want to quieten down a fuel pump-if posssible. Going to try some at a rate of 4 oz per 10 gallons of gas.
BTW, I tried Lucas ULC but not sure it did anything at all. FP seems to make car smoother. However, the cost is too much for me.
MMO does offer upper cylinder lubrication, I would suggest using a good fuel system cleaner like Redline and then going to the MMO.
The other thing I tell people is to make sure you fill up your gas tank when the fuel gauge is reading 1/4 a tank, the reason is that the gas in your tank cools the fuel pump, if its in your tank, if the fuel level gets to low then the fuel pump can get hot and you do not want the fuel pump sucking gas at the bottom of the tank if there is any debris at the bottom of the gas tank.
I have used Redline, Techron and Regane. Mostly used 93 octane Chevron fuel with Techron. Thanks for the keeping tank partially filled at all times. I try to do that.
