quote:
Originally posted by bsdbytes:
I was curious as to what you guys use to keep track of everything (software, spreadsheet, paper...etc) or any tips that you could offer. Mike
I'm become a minimalist when it comes to maintenance records. I make brief notes with date and milage in the back of the owners manual, adding blank pages if necessary.
If the maintenance is described in the owners manual, I refer to that.
Example:
4 Jan 04 12,547 miles: 15,000 mile maint plus new framestat and muffler bearings.
Now that I have a Corvette, I'll probably go back to my old system which was:
Keep a three ring binder with the pages in chronological order and receipts taped to pages at the right date, intructions and warranties for new accessories also go in the binder, also in chronological order. The three ring binder approach also makes it easy to keep any sort of notes, pictures, what to look out for next time, tools required, etc.
Both systems have one thing in common, they are quick and easy so they are more likely to actually get done.
I don't use a computer based system because it's a bit more hassle to do and is therefore less likely to get done. If you are being thorough, you also need a system to store paper, so the computer can't do the whole job anyway.
The most important thing is to pick a system you will actually use and stick with. I find for me that if it requires much extra work to record maintenance and file away important paper work, it doesn't get done.
As long as you file away the information in -any- retrievable form, you will find the time to recover the data if you need it. If you don't file or record it someplace, then it is lost forever.
[ January 04, 2004, 04:02 PM: Message edited by: XS650 ]
