Originally Posted By: sprite1741
That magnet will trap particles on the dirty side of the filter in a big clump. A large volume of flowing oil is concentrated in a small area. If the filter has an internal bypass and it opens, like on a cold start some that material could be pulled right past the filter into the engine. As the magnet saturates, the crud farther away from the magnet is not held on by as much force. Many manufactures including GM install a magnetic drain plug as OEM equipment. The oil settles in the sump and the magnet will hold the particles just fine. Plus easy to see a problem during oil change. Put the magnet on the filter at your own risk. The bad possibility outweighs the good.
Ive seen this scenario described before - not sure I subscribe.
The particles that are trapped are rarely to never caught in one pass in that they are so small they simply go through your filter anyway so your filter isn't stopping them. to begin with.
Second is "big clumps" wont stick to the filter media without pressure either, and will fall into suspension when you kill the engine - Only to be stirred back up and out the bypass when you fire the cold engine oil combo next round.
You are better off With a magnet to try to catch and hold it either way in both scenarios
The magnet can only help either situation.
