hoping someone here may be able to diagnose my problem as it is driving me nuts. i have (just recently purchased) a 2004 mach 1 w/ DOHC 4.6 engine which has began tapping/ticking when it gets up to operating temp and only at idle. the noise is on the passenger side and is not under the valve cover but its also not in the oil pan. it is somewhwere between. i dont think it is an exhaust leak because the noise happened immediatly after an oil change (went from amsoil 5w20 or 5w30 the original owner didnt recall, and amsoil filter) the noise goes away immediately off idle and returns a few seconds after resuming idle. ive tried from 5w20 - 10w30 oil. all plugs look perfect........any thoughts on a cause and a cure ? thanks.
