M1-HM is API-SL. Why?
Dickson, TN.
It appears that the M1 HM variant is their only gas engine oil that doesn't carry the latest API rating (it's API-SL rated).
Why is that?
I am aware that just because an oil carries the most recent rating, that doesn't necessarily mean it's better than oils with an earlier rating.
Just curious.
M1 HM a thick 5w30 with extra wear additives for high mileage engines. So it doesn't make the API's energy conserving catalyst requirements for SN.
Originally Posted By: LeakySeals
M1 HM a thick 5w30 with extra wear additives for high mileage engines. So it doesn't make the energy conserving catalyst requirements of SN.
That's what I was told by my mechanic as well. Bad eco HM oil!!
Probably due to ZDDP content being too high for SM/SN. They also lack the ILSAC starburst.
Also note that GC is also SL and not ILSAC.
The low ZDDP limits only apply to 20-30-wt oils. The xw40's are allowed to have more zinc/phos in them, which is why M1 HM 10w40 *is* SN
I don't plan on using it, as my Tacoma has had M1 or M1-EP since I drained the FF @ 3K.
However, if you look around, you'll find it's generally held in high regard around here.
