Right - about as likely as when Fram oil filter pricing floored as all the reports of cheap construction began accumulating on BITOG... (EM's finally wised up the "sucker-born-every-minute" mindset of Joe Consumer.Quote:
This is rather shocking. ... Will M1 price suddenly floor?
Quote:
Quote:
Thank you for your inquiry,
Not sure who told you Mobil1 motor oils are hydrocracked, Mobil1
motor oils are 100% synthetic, utilizing the PAO technology (groupIV)
and a proprietary blend of additives that are tailored specifically for
each viscosity.
This is the response I got from Mobil. They probably didn't even tell their tech staff. LOL
Do you think this will impact the elections?![]()
Quote:
I wonder if Amsoil will make the switch?
Quote:
Quote:
I have done a few factory fill M1 corvettes Cadilacs and when I cut open the filters with over 10000 miles there was
a small amount of sludge in the filters
...LOL yeah in the filters, where it should be. I guess that Honda test that showed M1 to outperform every oil on the self was just bogus? LOL. Hey if you don't like M1, thats fine. I know of a good oil that uses 4-balls to compare wear between oils. Go check them out.
Quote:
the filter had sludge from the oil inside the engine, comprhende amigo? yes the filter catches sludge the fact that sludge is "INSIDE" the engine is NOT ACCEPTABLE for my PAO priced crude based oil
Quote:
Come on people. One unverified test and an allegation that one grade of M1 is supposedly G-III, and half of you seem to be accepting it as a firmly established article of faith. Tom, not a personal slam against you, but we need more than that. You need to do some repeat runs, showing properly controlled conditions, and post some data. As my old HS algebra teacher used to insist, "show your work!"
I've asked Mobil myself a couple times over the years, and got the same answer Buster just did: the product line is based upon predominantly PAO, with other syn fluids balancing out the mix (e.g. esters and ANs). If Mobil is still saying G-IV, I'm inclined to accept that, for two reasons. First, if it's not, they're facing huge consumer fraud problems for representing that it is. Second, IMO, Mobil's specific statements simply outweighs Tom's information, at least in its present form.![]()
Quote:
From what I am reading here it appears that Mobil is giving mixed signals themselves, and it is quite possible that they do not share specific formulation information with their sales & customer service folks beyond the party line "full synthetic". Pretty common in business.
Quote:
I think you've summed it up nicely. I agree with you. Thanks for taking the time to run these tests for us nut cases.![]()
