Hi
This M1 Truck and SUV 5w-30 fill had 5800 miles on it when sampled. FP60 and FC20 used,std dosage.
M1 Truck and SUV 5w-30 is col 1.
M7500 5w-30 with FC20, FP60 and VSOT is 2nd col.
Uni. Avg. is 3nd col.
Aluminum..........2.......3........3...
Chromium..........1.......1........1...
Iron.............12.......8.......13...
Copper............9.......9.......18...
Lead..............5......14........7...
Tin...............0.......2........1...
Molybdenum.......68.....183.......52...
Nickel............0.......0........0...
Manganese.........0.......1........0...
Silver............0.......0........0...
Potassium.........0.......2........8...
Boron............36......48.......47...
Silicon...........7......16.......11...
Sodium............9.....134.......13...
Calcium........1672....1699.....2089...
Magnesium........10......12......111...
Phosphorus......482.....579......715...
Zinc............591.....677......868...
Barium............0.......1........0...
Blackstone: Low insol due to filter change at 4k.
TBN was 4.0. Lead made a big improvment. All wear metals at or below univ avgs. Low silicon shows good air filtration. We found no fuel, water or anti freeze in sample. Viscosity measured in correct range for a 5w-30. You could try 7000 miles for next sample and check back.
Flashpoint 390
SUS Visc. 59.5
Fuel < 0.5
Anti freeze 0.0
water 0.0
insolubles 0.2
This M1 used only FC20 and FP60 additives unlike the previous M7500 which also included vsot. A PF47 filter was used for the first 4k miles, after which the ST ecore for the remainder.
1/2 qt added at filter change.
Flashpoint 390
SUS Visc. 59.5
Fuel < 0.5
Anti freeze 0.0
water 0.0
insolubles 0.2
