M1-108 run for 9k miles/2 OCI
No, this is the 2.0 liter FS-DE engine. Same as a 4 cylinder probe, 626, MX6 and a couple of other cars. It is also a bullet proof engine as long as you change your timing belt on time. The FS 2.0 and the BP 1.8 (miata Engine) are fairly similar in design with the FS being more oriented for mid range performance and the BP for upper range performance.
Can an M1-110 fit?
Yes, the 110 can fit I am pretty sure. I will probably move to it. I currently have the longer version of the purolator boss on there. The 14610 instead of the 14612. Or vice versa.
