Just received this DT40 UOA from Cat Labs tonight. Low mile run, but in sump from 8/2023 to 8/2024. Driven DT40 5w40 8 qts. Topped with 1/2 qt of Castrol Edge 5w40 Euro.
Prior two fills also used Driven DT40 5w40. Last 2 columns of Blackstone report below. Note these short mile changes indicate lower zddp possibly due to DT40 competing with prior oils used in the earlier changes (such as Liqui Moly Leichtlauf Hi Tech 5w40 at 83,388 change and 82,267).
FlatSix/Raby has advised that DT40 doesn’t play well with some other blends (like M1 0w40) and it could take two fills or a short run of Driven 30wt to get all old oil out of engine before seeing true impact of DT40.
