Good morning,
This is a multi-part question.
I'm considering switching from dino to synthetic in my wife's 2005 Volvo 2.5T at the next oil change, which will be at 67500 miles, following Volvo's recommended schedule. We bought it at 40k miles and I have used Castrol dino since then; the manual says that the dealer only uses synthetic on special request, so I assumed it has used dino all its life. Excerpt from the owner's manual is posted below*. Too late to switch to synthetic at 67k?
I also have a 2002 BMW 330i with 101k; I have been doing 7.5k OCI (half the recommended 15k) using BMW-branded 5W30, which to my understanding is simply repackaged GC.
For simplicity's sake, I'm considering switching both to Mobil1 0W40, which (to my knowledge) is the only readily-available, off-the-shelf oil that meets BMW LL-01 specification. I've searched a bit, but haven't found any specific pros or cons for M1 0W40 in the Volvo 2.5T. The manual recommends 5W30 dino Castrol.
Also of note, we life in Florida so it stays pretty warm, only one or two days out of the year does it dip below freezing, and much of the summer it's 90+ outside. Neither of these are race cars: The BMW is driven primarily on the interstate, about 25k per year; the Volvo is much more about-town, and she usually drives pretty gently. It IS a turbo, but to tell the truth she rarely revs it high enough that the turbo sees any action.
Primary goal is motor & accessory longevity; secondary goals are fuel economy, keeping only a single oil type in my garage, and being able to drive to Wal-Mart or Autozone and pick up oil when I need it.
Comments?
Thanks,
- Nathan
From the Volvo S60 owner's manual:
Oil quality
Engine oil must meet the minimum ILSAC specification GF-2, including ACEA A1, API SJ, SJ/CF and SJ/ Energy Conserving.
Your Volvo has been certified to standards using ILSAC oil specification GF-2 5W-30. Volvo recommends use of oil with a quality rating equal to or higher than ILSAC GF-2. Equivalent and better oils include ACEA A1, API SJ, SJ/CF, and SJ/Energy conserving. Lower quality oils may not offer the same fuel economy, engine performance, or engine protection.
Volvo Cars recommends Castrol.
Depending on your driving habits, premium or synthetic oils may provide superior fuel economy and engine protection. Consult your Volvo retailer for recommendations on premium or synthetic oils.
Oil additives must not be used.
NOTE: Synthetic oil is not used when the oil is changed at normal maintenance services. This oil is only used at customer request, at additional charge. Please consult your Volvo retailer.
Comments?
Thanks,
- Nathan
Oil quality
