Code:
Vehicle 1990 Saab 900, 2.0L 16v I4 (N/A)
Miles on engine 194,211
Oil type Mobil 1, 0W-40
Miles on oil 20,017
Time on oil 21 months, 1 week (30.Oct.04 – 05.Aug.06)
Oil capacity 4 qts
Total OCI oil added 2.9 qt
Oil filter Purolator PureOne PL10017, changed at first UOA sample (11,892 mi)
Air filter K&N drop-in, last cleaned at 150,000 miles
Driving Use 50% city, 50% hwy – daily commuter (40 or 65 miles on surface streets) & weekend errands
Sampling method Vacuum pump via dipstick fill tube
Copper 24
Iron 29
Chrome 2
Lead 5
Aluminum 3
Silicon 8
Molybdenum 65
Sodium 6
Calcium 2726
Tin 0
Potassium 1
Magnesium 40
Zinc 1031
Water Neg
Glycol Neg
TBN -
Viscosity 13.3
Lab S.O.S. Fluid Analysis, H.O. Penn Machinery
Well, this was the 3rd & final sample from my 20k mi M1 0W-40 long-term test. I feel pretty good about the results & would recommend this oil to anyone looking for a great, long drain, year-round oil in nearly any car.
Here are my previous UOA results for this run of oil.
The only Abby Normal occurance I can recall was a continuation of the PCV oddity. (See previous UOA comments.) After drilling out the port for the 4mm ID hose, the engine's resting idle was continuously high at 1200-1300 rpm. (Normal idle should be around 800-900 rpm.) Gas mileage improved slightly after doing this, so I didn't worry about it for the remainder of the OCI. I've now replaced the 4mm ID hose with a 3mm ID hose & the idle rpms have returned to their normal range.
Let me hear your questions & comments!
Miles on oil 20,017
Oil capacity 4 qts
Copper 24
Iron 29
Chrome 2
Lead 5
Aluminum 3
Silicon 8
Molybdenum 65
Sodium 6
Calcium 2726
Tin 0
Potassium 1
Magnesium 40
Zinc 1031
Water Neg
Glycol Neg
TBN -
Viscosity 13.3
