Just replaced my driveline (rear cassette, middle chainring, rear derauiler jockey wheels, and chain). The chain was a SRAM-pc830. The box said that it was already lubed, so I added none (I did have to clean my hands afterwards, so there was something on the chain). On my first ride, for around the first 20 miles it made noise that kind of reminds one of a roller coaster when it's going uphill. It was super annoying, at least when there was no traffic passing by. The noise seemed to be coming from the lower jockey wheel. It's almost as if the lower jockey wheel needed to wear a little first, as the chain has issue dropping into the it, or maybe I should have lubed the chain first.
Did I make a mistake by not lubing the chain before use? Searching the internet suggests conflicting results.
I don't recall having this issue before as I have changed chains many times. The last time I changed a chain was in 2021 and I forget if I lubed that chain before use. If it matters this chain that I just installed was purchased in April 2021, as I keep a spare chain, just in case.
The only thing I did different this time that I can think if is that I used the SRAM PowerLink. I don't think that was an issue here.
