New to me 2014 Tiguan R line; questions about lube, internals, etc
It's probably the best bang for the buck you can buy now that WM stocks it for under $30 for 5 quarts. I run it in both of my vehicles, it's so good I even replaced my morning coffee with ESP and no regrets so far.
0w30 was easily available, but 5w30 wasn’t in stock and it wasn’t even in stock to ship it.
Mobil 1 0W-30 ESP is shear stable. It meets the same approval requirements as the 5W for stay-in-grade.
It’s a common Internet “rule” that less of a grade spread is always better but that’s actually not true. First off it wholly depends on the engine design as to whether mechanical shear of the VM is even an issue (and it rarely is), and the quality of the VII and base stock composition are critical factors. EM does not use inferior VII. There is no reason to avoid the Walmart product especially in light of being $10 less expensive.
All true, but ESP 0W30 and 5W30 share a lot of chemical components, so between the two, 5W30 will be more stable and have lower Noack.
On other hand, ESP 0W30 is still exceptional oil compared to many other 5W30 oils.
I ended up doing 5w30 ESP, and of course I’m thinking about the next one. 😆. Would VW 511 00 be over kill in this engine. I don’t care about the fuel economy or the extra cost of the oil, I just want good protection.
…. And another thought. If 0w40 Castrol and 0w40 M1 are now SP, wouldn’t they be fine for a TSI since the calcium is so low like a Mid saps oil? Doesn’t it put VW 502 00 back into the conversation for a TSI motor if you want something more shear stable. Even Motul xcess gen2 5w40 would be fine.
EA888 2.0T doesn’t have LSPI issues. There were occasional instances of failures that are reminiscent of LSPI, but it is questionable.
LSPI paranoia is caused primarily by Korean/Japanese/American builders. European engines are collateral damage in that paranoia.
Only VW engine that had LSPI issues was old 1.4 turbo/supercharger engine that never made its way to US.
In regard to carbon buildup, there really isn’t a difference between new SP vw 502 vs vw 504 oils either?
Old lubrizol study showed VW502.00 leaving 167% more deposits than VW504.00. So, there is that.
I appreciate your patience while taking my questions. What is the difference in formulation between a sp vw 502 and a vw 504 in regard to saps content? Is it a single ingredient that is higher in one oil over the other?
Edit, I read an article about saps and that the difference is a lower amount of Phosphorous and Sulphur.
From my Brave browser search AI:
VW Oil Specifications Difference​
Based on the provided search results, here’s a summary of the differences between VW 502.00 and VW 504.00 oil standards:
VW 502.00:
  • Older specification, suitable for older Volkswagen engines
  • Formulated with high-quality base oils and additives for excellent engine protection and performance
  • Can be met by semi-synthetic oils, such as Chevron Supreme 10w40 Semi-Synth
  • Typically available as 10W40 or 5W30 viscosity grades
  • Suitable for 10,000 km (6,214 miles) or 1-year servicing intervals
VW 504.00:
  • Newer specification, designed for modern engines meeting strict emissions standards
  • Formulated with advanced additives and base oils for improved engine cleanliness and protection
  • Only available as a full synthetic 5W30 viscosity grade
  • Suitable for longer servicing intervals, up to 2 years or 40,000 km (24,854 miles), depending on driving conditions
  • Meets stricter specifications, including low SAPS (Sulfated Ash, Phosphorus, and Sulfur) and ACEA C3 standards
Key differences:
  • Viscosity grade: VW 502.00 is available in 10W40 and 5W30, while VW 504.00 is only available as 5W30.
  • Additive package: VW 504.00 has a more advanced additive package for improved engine cleanliness and protection.
  • Servicing intervals: VW 504.00 is designed for longer servicing intervals, up to 2 years or 40,000 km, while VW 502.00 is suitable for 10,000 km or 1-year intervals.
  • Emissions standards: VW 504.00 is designed for modern engines meeting stricter emissions standards, while VW 502.00 is suitable for older engines.
In summary, VW 504.00 is a more advanced oil specification designed for modern engines, with a focus on improved engine cleanliness, protection, and longer servicing intervals. VW 502.00 is an older specification suitable for older engines, with a focus on basic engine protection and shorter servicing intervals.
VW 502.00:
VW 504.00:
Key differences:
Wow, I’m still not to impressed with AI. Quite a few incorrect facts there. Thanks for trying to help, but AI gets a lot of things wrong and I wouldn’t be using it as my only and absolute resource for information. Thanks again.
VW 502.00:
VW 504.00:
Key differences:
That is why I tell my students that AI will get them kicked out of school.
I love how you ask for the difference and then just say, "NO!"
Here's another resource that took me 2 minutes to find that completely redeems the "ignorant AI" search result:
https://www.oilspecifications.org/articles/vw_motor_oil_specifications_explained.php
What AI got right:
- Oil grade difference (504.00 is 5w30 only)
- Base stock difference (longer intervals, less thickening, better fuel economy)
- Additive difference (less wear, cleaner, longer OCI)
- Lower SAPS (emissions compliance)
That's pretty much all you need to know.
It's better for newer cars.
What AI got right:
Even that’s not correct, VW 504 00 approval also allows a 0W-30 grade. The 502 00 isn't right either, that allows 0W-30, 0W-40, 5W-30, 5W-40, 10W-30 and 10W-40.
Wear limits are also identical between 502 00 and 504 00 and the viscosity increase limits are the same. I think the AI is still a mess.
What AI got right:
I’m sorry, but still some issues here. Thanks though.
What AI got right:
1. VW 504.00 is XW30, 5W30 or 0W30.
2. VW 504.00 does not come in XW40 flavor. Hence, overall on average will have better fuel economy. VW 502.00 comes also in XW30 flavor. Minimum HTHS will be the same. No fuel consumption benefits between two oils of same grade.
3. Additive difference is the key when it comes to the intended purpose. That is under emission part. VW 504.00 has to have less byproduct or sulfated ash. Wear? Hmmm, we have studies done by Mercedes that prove that high SAPS oils (VW502.00 category, or ACEA A3) have less wear bcs. they do have richer additive package.
4. VW502.00 is constantly updated. It is NOT an old specification as responded by AI or your supplemental brain. Approvals, unless completely abandoned (like VW503.01), are constantly updated. Last time VW502.00 was updated was 2022.
Again, do yourself a favor and read; don't ask a machine questions. You have enough material here in the European section to find out everything. If you are lazy to read, don't pretend you are doing any favors to others because you are misleading them.
I ran 2 OCI of M1 ESP 5w30. Currently on Motul X Clean + 5w30. Arizona summer is around the corner and I will be going Motul vw 511 00 just for peace of mind. It will help with my chain anxiety. 🤣
