LSJr tests and discusses DexosD babymax oils
VA
On tonight's episode of Oil Geek, LSJr gets coffee for Jeremy Wagler and his assertions break the BITOG HDEO forum.
0) DexosD is only 0w-20 (incorrect.)
1) Run 40wt in your LZ0/LM2.
2) Higher viscosity means higher peak torque.
3) Delvac 5w-40 CK-4 (current formulation) is PAO/ester.
4) Mobil ESP 0w-20 is better than Delco bottled 0w-20.
5) For LSJr, lower wear metals tells the whole story.
6) Modern VIIs in high-spread oils hold up pretty well, despite warnings from our grandpas as they taught us to change oil using fram orange cans.*
* "That new fangled 5w-30 breaks down to a 5 weight. Ain't no good."
scientifically this makes complete sense for a low rpm torque making engine. first thing comes to mind would be a large semi they're not running low viscosity oils.
More boundary layer of the 0w-40 giving more power and less wear metals in a low rpm diesel engine makes sense. Even in a gasoline engine I think it would be good for me as I don’t live above 3k rpm 90+% of the time.
Exactly what several members here explained to me for my 3.0 a while ago when I first joined BITOG. Took me a while, but I finally saw the light.
I noticed he didn't say much about the TEOST. He mentioned the results were consistent, which they are. I'll message him and see what specific TEOST test it was and what the passing range is. Goes back to the question of its relevance. I don't have an answer. Amsoil uses it and actually did a relatively recent test of Mobil 1 High Mileage and Valvoline High Mileage and both technically failed the TEOST. Valvoline and Mobil know what the TEOST is and can run them in-house. So I'm thinking they either chose a chemistry that gives up some deposit prevention for another benefit, or TEOST isn't as accurate at predicting deposits. This is where Red Line, HPL etc. come in.
*Several years old.
I noticed that as well. My thinking is it wasn’t the focus/purpose of this video so he didn’t expound on it. Or, like you said, isn’t really a relevant test. Will be interested to hear his response
