I didn’t initially pick up that the absolute numbers were that small.View attachment 344077
To me all of those wear metal numbers look statistically indistinguishable from one another, I sure wouldn't use them to make the claim for or against a specific oil.
That said, since the three ESP weights are using the same additive strategy you can logically conclude that the -40 must provide better wear protection on account of the higher HTHS.
I was thinking the same thing as I watched the video last night.@Hohn i wonder if the higher viscosity / higher peak power helps explain your mileage improvement that I saw awhile back.
Probably why Mobil capped the mileage rating to 12k for ESP. They know their own product. I've said many times in the past just because it's a Euro oil don't assume it outperforms top shelf API/ILSAC EP oils in ALL areas. EP likely has higher detergent and AO than ESP and therefore can go a bit further. Something to at least consider. And we're seeing Valvoline Restore and Protect being used in engines that ran on Euro oils being cleaned up a bit too.Looking at the ESP 0W-30 results the PDSC is low at 44 minutes(not very impressive). Inline with a racing oil not made for extended intervals. The TEOST of 50 puts it in the middle of some of the best in the business.
Yes, we saw that with one of the other wear "tests" too.He shows data that says the babymax has lower wear metals as miles increase.
I wonder if that simple fact invalidates all his wear metal conclusions. The engine was “breaking in” on the test stand. Oils tested later in the test have lower wear metals.
Correlation but not causation.
I mean, it IS a marketing sheet, lol.Probably why Mobil capped the mileage rating to 12k for ESP. They know their own product. I've said many times in the past just because it's a Euro oil don't assume it outperforms top shelf API/ILSAC EP oils in ALL areas. EP likely has higher detergent and AO than ESP and therefore can go a bit further. Something to at least consider. And we're seeing Valvoline Restore and Protect being used in engines that ran on Euro oils being cleaned up a bit too.
Also, why Pennzoil ranks Pennzoil Ultra Platinum greater than their Euro oil in their marketing sheet?
He doesn’t need to run the Delco oil again. He compares his results to his customer’s results which according to Lake match up. Unfortunately he didn’t show his customers results (probably not allowed to w/o permission?) on screen so we’re taking him at his word. But I don’t see what he would gain from lying about his customers results so I believe what he is saying.It would've been as easy as repeating the delco oil at the end to re-establish the baseline. If wear metals repeated, boom, you've established causation.
But he's a certified lubrication expert and has a youtube channel. After all, he said Delvac ESP 5w-40 CK-4 was PAO/ester.
From the horse's mouth:
It's really the notion of comparison here that's the most bogus.He doesn’t need to run the Delco oil again. He compares his results to his customer’s results which according to Lake match up. Unfortunately he didn’t show his customers results (probably not allowed to w/o permission?) on screen so we’re taking him at his word. But I don’t see what he would gain from lying about his customers results so I believe what he is saying.
There are a few people on here who use ESP 0W-20 in their gasoline engines. Also, I bought 3 jugs of it for a friend's hybrid SUV after reading and taking advices from the forum.On tonight's episode of Oil Geek, LSJr gets coffee for Jeremy Wagler and his assertions break the BITOG HDEO forum.
0) DexosD is only 0w-20 (incorrect.)
A good catch.I was thinking the same thing as I watched the video last night.
As a note of clarity— it’s not peak power, but peak torque. Typically peak power will be less because of the higher RPM pumping loss.
It was really striking that he showed a graph that 0w-40 ESP has lower traction than than the 0w-20 Delco oil. We talked a lot about traction in my other SAE 40 and such threads, and I surmised (against intuition) that it’s possible the thicker oil had lower traction.
It’s possible for a thicker oil to have both lower traction AND higher viscous pumping. This is why you see thick oils have an advantage at low RPM where traction dominates and why they lose to thinner oils at higher RPM where viscous pumping dominates.
I’m over 2200 miles on this OCI now and tank mpg has stabiliized at well over 1mpg better than the 5w-30 Valvoline Restore and Protect and 15w-40 were able to deliver. (Seasonality probably explains the 15w-40 not besting the Valvoline Restore and Protect 5w-30 like the mnonograde does).
So indeed, it’s possible for a higher viscosity grade oil to be a lower traction oil.
This is the graph that blew my mind.
Because is probably their best selling "superior full synthetic" oil (vs their other "premium full synthetic" oils). However, the Pennzoil Platinum Euro 5W-40 is as extreme performance as Ferrari engine gets.Also, why Pennzoil ranks Pennzoil Ultra Platinum greater than their Euro oil in their marketing sheet?![]()
The issue is that:He doesn’t need to run the Delco oil again. He compares his results to his customer’s results which according to Lake match up. Unfortunately he didn’t show his customers results (probably not allowed to w/o permission?) on screen so we’re taking him at his word. But I don’t see what he would gain from lying about his customers results so I believe what he is saying.
3.0L LZ0/LM2Please forgive my ignorance. "Babymax"?
What temps run lower in this engine? Coolant? Oil temps, for example, hover around 250F in the 3.0.There are a few people on here who use ESP 0W-20 in their gasoline engines. Also, I bought 3 jugs of it for a friend's hybrid SUV after reading and taking advices from the forum.
About the diesel engines—they not only run at much lower RPM but also at lower temps. as well, compared to gasoline engines.
Generalization does not apply to the LM2/LZ0. Look around for data on typical coolant/oil temps. "Much."About the diesel engines—they not only run at much lower RPM but also at lower temps. as well, compared to gasoline engines.
The combustion of diesel emits less heat than gasoline.What temps run lower in this engine? Coolant? Oil temps, for example, hover around 250F in the 3.0.
