I have a 50 ft tripod with 3 ft base antenna tower I want to lower, paint and then put a new antenna on. Currently does not have one. Last time back in the day I could lower it but had trouble raising it. What I have is a 120v 1000 lb hoist. The problem is the angle I was using as it was too acute.
So I'm thinking of using a pully up high in a spruce tree, then down to another tree to secure the hoist then string it up to the tower. It would give me a +10 ft height for the pully and some leverage.
Here's were it will land
Here's looking at it from the direction it needs attached from.
Here's how I plan to string it. Attach the hoist to the base of the tree on the left. Put a pully about 15ft up on the tree then straight out to the antenna. It should give me more leverage and clearance for the cable on the corner of the roof. Green line would be level when the antenna is standing. The tree with the hoist attached is about 5ft out in front of the spruce.
Open to any other ideas. I also could get my small car to pull it up under that spruce tree. Maybe the mower has the guts.
