- Joined
- Jun 17, 2024
- Messages
- 42
2009 Toyota Matrix 2.4L, when cold starting the car in the morning, not sub zero degrees or anything just after it has been sitting, it turns over and starts right away but for a few seconds seems to struggle or be low on power, no dim lights or anything and rpm’s seem normal for starting. Replacing my bad old battery seemed to make things better and not as noticeable. I had a previous thread posted where I believed this was only on an incline but that doesn’t seem to be the case anymore. There are two things I think it could be but let me rule out what I think it isn’t. I don’t think i have a fuel pressure problem and the car doesn’t crank extra just feels low on power after sitting, new spark plugs and battery and my idle RPMS are right where they should be so i don’t think it’s the IACV. My leading theory on what it could be is the oil struggling to be pumped through the system, i only say that because I have been putting Lucas Oil Stabilizer in it for a few years now and just recently I looked into it and from my understanding it makes the oil thicker in a sense so I want to stop using it. I never really paid attention to the starting of my car so the problem could have always been present. My second thought is maybe my starter is going? But this only happens when the car has been sitting. Finally I did notice when changing the battery on the negative lead form the car you could see the copper on the inside of the connector, like the thing you put on the terminal and tighten on on the inside of that.
That’s really all I got, don’t really have any other symptoms besides some ever so slight idle shakes randomly but it has always done that, new engine mounts so I know it’s not them for that issue, Inasusme if my oil is thicker it could cause that as well but i’m not sure. The issue isn’t very concerning but it feels like it might be soon. Again the new battery helped the problem and alternator is charging it fine I used a tester. Any advice is helpful i’ll try to go for an oil change tomorrow regardless as I don’t think i’m buying the lucas doing anything of use anymore
