2009 Chevy Cobalt Low on Power
PA
I have had my 2009 Chevy Cobalt (2.2L automatic) for 4 years, bought in April 2022 with 145k miles.
It currently has 189k miles, and in the past month or so, I have noticed that it feels somewhat low on power. It was never a "fast" car, but always felt like it had adequate power.
As it sits currently:
-Rear drums and shoes were replaced 45k miles ago
-Front brake pads are getting close to ready to be replaced, within the next 10k miles or so
-Air filter has 15k miles on it
-Tires are all inflated properly, matching set, kept rotated
-No check engine light, and no codes stored according my little handheld scanner
-Fuel pump was replaced about 20k miles ago
-Car is due for an oil change in a thousand miles, but I have never noticed a change in performance before when close to being due (every 5k)
-Car starts right up with no excess cranking or anything like that
-I have been running the A/C sometimes on hot days, which I know can add more load to the engine, but again, have never felt a lack of power before
-I have gone through several tanks of gas, I always get gas from the BJ's gas station near me, which sells tons of fuel, so I imagine the fuel is always fresh
The only thing I can think of right now is the spark plugs, which I replaced when I got the car, 45k miles ago. The manual calls for replacement every 100k miles, so technically they should be fine, but I don't know where else to start. Perhaps aftermarket plugs don't last as long as the originals? I don't know what brand they are, just whatever the recommended plugs from Advance Auto.
Any thoughts or suggestions would be greatly appreciated, thank you.
At this age/mileage, maybe the catalytic converter is plugged?
I had the exhaust repaired last summer (flex pipe and the pipe near the muffler rusted off), but even as I'm typing this, I guess that has nothing to do with the catalytic converter possibly being plugged.
Wouldn't that normally set a check engine light?
What plugs, If they were counterfeit which happens even at local parts stores due to scum bags returning fake junk they know is fake that might be the issue. Someone on here saw that at the store they worked at. Other than that I wonder if the maf isn't metering right. Unplug and drive it for a little as the the operating characteristic of its default logic they usually revert to when it's not metering might show something. Also check the air filer just in case some rat or squirrel didn't mulch it and clog the maf. Saw that with a friends farm truck when trying to help him start it.
Not always. I've had them be noticably down in power due to a plugged cat with no CEL
There are way to many variables to be able to begin to diagnose this without more info. I would suggest checking to see if there are any Cobalt forums to look for common issues with your year and model.
My dodge neon had this happen. The e brake cable had stretched causing dragging on the rear drums.
Another vote for restricted cat converter. Believe it or not I have an 05 bought new that has 394K+ miles and still going strong. Original engine, transmission, fuel pump (must not be an issue like the vortec era stuff), and A/C components still functioning as they should. Did timing stuff after 300K - was getting noisy at startup. Somewhere in the 300's got a check engine light code for O2 sensor. Couldn't get it loose on the car so removed that section with cat from both flanges. Was going to try to get sensor out but prior to that took a flashlight and looked into converter - wow - looked like solid white/grey ash. Not sure how it ran as well as it did, but I did notice a difference with another cat. I don't drive it hard obviously.
