How can an oil brand have low noack and low hths w/o that being a feature of the base oil? Since both are high heat tests would you either expect good numbers in both, or bad numbers in both, not split? Unless you achieve a low NOACK with some type of additive other then base oil? Good numbers as in metal protection film strength not good as in fuel mileage considerations.
