So, I've posted previously about replacing my plugs @215,000 miles due to somewhat rough idle.
Original factory plugs came out, and Autolite double platinums went in.. non fine-wire.. Didn't help, so I replaced them again @ 225,000 miles with new NGK fine-wire plugs and also put on new Coil-on-Plugs. This also hasn't helped. In fact, over time, the roughness has gotten worse, and the car has started throwing P301 codes "Misfire on Cylinder 1"
I've been using the Torque Pro app on my phone to look at the details, misfire frequency, etc..
The car only seems to really be rough @ low speeds, mostly idle, and seems to be between about 10% and 15% misfires reported.
At highway speeds (70-75 MPH), it runs smooth, and most of the time, I'm only seeing around .005% misfires.. as in less than 200 misfires reported in Torque over 30 minutes of driving.
The catalytic converter seems to come up to operating temp fast. Like, after 1 minute of driving in the morning, it's already over 900 degrees. On the highway, cruising @ 70MPH, it's steady around 1260 degrees. If I punch it to get on the highway, it gets up to about 1400 degrees.
Even up through my last oil change @ 224,000 miles, the car was not using any noticeable amount of oil. No dripping, no burning.. also, no fuel dilution, and no antifreeze in any of my used oil analysis.
Coolant is clean and doesn't move up or down.
So I ran a compression test. Yup, Cylinder 1 definitely has a compression problem.
My gut says that I probably have a burnt exhaust valve.. but I was curious to get feedback from the BITOG community.
... so what do you place your bets on?
