- Joined
- Aug 4, 2021
- Messages
- 138
1999 gmc Sierra 1500 4.3 vortec from a 2003 silverado. Check engine blinking misfire cylinder 1. Exhaust Billowing grey smoke, rough idle, oil on spark plug 1. Did compression test and it’s dead zero. All other good compression except for cylinder 5 which is same side as cylinder 1 but at least has compression. I’m thinking broken piston or rings. Will not be rebuilding will be looking at dealerships. But is dead zero compression possible with broken rings or piston? I re checked multiple times all dead zero zero movement all other cylinder 160 except number 5 which was 60. Would bad heads cause a dead zero?
