Okay guys, back to the problem I posted about here:
http://www.bobistheoilguy.com/forums/ubb...rue#Post2374883
This thread will give the back story. Anyhow, a week ago I thought it was the coil as it firing on the #2 cylinder, which is the dead cylinder. New coil came in a few days ago and I changed it out today. We now have fire for all cylinders from the coil but #2 is still dead. I went out and rented a compression gauge from AZ and checked the compression as follows:
Warm car up to operating temp
Remove all plugs
Screw gauge into plug hole, open throttle all the way and crank. Took down highest reading.
I repeated this 2x and came up with the same numbers. Could someone decipher this for me?
#1: 120 psi
#2: 90 psi
#3: 120 psi
#4: 110 psi
I have no clue and no luck looking around online on what the numbers are supposed to be. As always any help is very much appreciated.
Remove all plugs
#1: 120 psi
#2: 90 psi
#3: 120 psi
#4: 110 psi
