2003 Dodge 4.7 V8, 320,700 miles.
At 180-185 operating temperature, I'm seeing about 18-19 PSI idle. While driving normally (1700-1750 RPM) I'm seeing about 50 PSI. When the trans kicks out of OD to climb a hill or something, the oil pressure will come to to about 60 PSI as the RPM increases.
At cold start, I see 60 PSI on the nose until everything warms up.
This is with Supertech 10W30 high mileage and Engine Restore additive. Added Restore about 100 miles ago in an effort to get a little better compression out of cylinder 3. A compression test resulted in 110-120 PSI average on all cylinders except for number 3, which was about 95 PSI.
The engine calls for 5W30, would it help anything or hurt to step up to a 10W40 at my next oil change? The hot idle oil psi just seems low to me.
