Originally Posted by exranger06
Originally Posted by meep
I'm wondering if you have a hot spot on a valve or piston top, causing occasional predetonation. You might be able to pinpoint that by trying a tank of 93 Octane, which would then reduce the occurrence. If a tank of 93 makes no difference, that's not it.
Is this a timing belt motor? a stretched TB in my experience caused occasional misses, especially at idle. Eventually it threw occasional misfire codes, but no mechanic diagnosed it properly - they all suggested wiring harnesses and injectors. I wouldn't have guessed it either, since it was a TB with only 36k on it. By luck, a WP failure drove the replacement, and the problem was gone. I compared the 2 belts and there was a notable difference.
No, he said he has a 3.0 V6. It has a timing chain. Pushrod, cam-in-block engine with a short chain.
Copy that and thanks - I'm not as familiar with this engine family. I'll keep my dollar in the hat for carbon buildup. Those compression numbers seem high to me for an engine of that era. My old 283 which was close to 11:1 had around 145-155. No way a regular octane engine should be up there, unless my memory is just totally off, which it could be.
