Took the ford in for a drive thru VIOC service, and they noted 290 cold cranking amps on the battery.
However voltage is fine.
Location is San Antonio TX. They recommended battery replacement.
Battery is walmart everstart with a date code 12/2019. Probably installed 2020 early.
Is this something that should be replaced right away or wait a month or so?
Original cranking amps is 590 I believe.
