Ive been reading up here for a lil bit now, and this place is awesome. Tons of Information to be had. But that doesnt mean Im not without my Questions. So, you guys could confirm my Questions, that would be awesome. Here Goes-
From what I've read, It is bad to let your Car Idle in the Winter Time. So, I guess I just wont start my Trans Am in the winter, and Wait for Spring, when I take it out. Im assuming this info is the same with my Daily Driver too, my 4runner. So, I should just start it up, and drive immediatly, but just drive very easy?
In the winter here, its gets pretty cold. So Im running Castrol GTX 5w-30, with a M1 Oil Filter. From what Ive read, this filter is very good, and Castrol is a good Dino Oil. So, In the summer, Should I run 10w-30, or 10w-40. Im not crazy driver in the 4runner, because its not a fast car. So, under normal Driving, Im assuming 10w-30 should be fine. But, If I decide to take it offroading, should I change to something else?
In the summer Also, Im going to be using my Trans Am more. What do you reccomend for Oil Weight in that car? Its a big engine (400ci 6.6L) and it has 67k miles on it. Although Im not going to kick the crap out of this car, since it is in such good condition, chances are, it may make it to the drag strip 1 or 2 times, and driven a little quicker on the High Way. but thats a maybe, depending on how much $ I have for gas in this thing. Should I be ok with 10w-30 or 40, when at the strip? And At the end of the fall, since it wont be drive a whole lot during summer, Would it be ok to keep the oil filter, but just change the oil before I put it away. It wont be anywhere near its max limit.
Also, Ive become convinced that 3k oil changes is stupid. So, I suppose the Castrol and the M1 filter should go for 5k pretty easily , Correct?
This was never really answered in my last Post. I asked "Does Castrol GTX High Mileage contain stuff that swells your seals". Thats a bad thing if it contains it right? Because I was thinking of changing both my cars (4runner at 165k) over to that oil, if it is better than regular GTX.
I think thats all the questions I have, and That should hold me over for a while. I know its a huge post, but you guys are nice people, so i know youll answer it
Thanks a ton
Thanks a ton
