Originally Posted by supton
Can they do a borescope--heck, can you? I'd be checking for scoring of the walls.
I actually ordered a borescope, which is supposed to arrive today, so I plan to have a look inside all 4 cylinders to assess the overall condition, and have a much more involved look inside cylinder 2.
Also, for what it's worth, when I had the valve work done on Cylinder 1 back in March 2017, I was able to take some photos of the cylinders and pistons while the head was off. This is a picture of Cylinder2. Please note that the dark lines inside the cylinder are just discoloration, as far as I can tell. I was able to run my fingernails inside #2 and #3, and they did not catch on anything.
As you can see, the cylinder was in pretty good shape roughly 60,000 miles ago.
I don't know if the cylinder can be bored out, and I'm not sure it's worth doing that vs dropping in a used or reman instead.
I'm wondering if an engine swap is the cheapest repair, a teardown is half of the labor (removal).
I'm not even considering doing a new engine at this point. They quoted me something like $6000 to do it, including the engine and labor. No freaking way. I might entertain going with a used engine, but even that's going to run a good $2000 or more.
Originally Posted by Trav
Before you go throwing money at it or tearing into it. Those numbers while lower on #2 are not low enough to induce a misfire, 90 or below then you may have one.
Good point. Granted, the fact that's it's roughly 20% low on just the 1 cylinder is certainly still a concern, at least it's not a big one.
I suspect some other issue is causing the miss but for the heck of it an inline engine is perfect for an overnight piston soak. GM, Chrysler, Subaru, Toyota all have a decent top engine cleaner you can pour a couple of ounces (2 or 3 oz) down each plug hole and let it sit.
Cool, I'll look into those. Just on the off chance that I can't find one of them, what would be another over-the-counter cleaner that would be comparable?
You will need to change the oil after doing this. Try it, its cheap and do a compression test after.
No worries - it's got over 6000 miles on the current oil/filter, so it's close to being due anyways.
Edit: You can get a leak down tester and compression gauge cheap enough (under $100 for both), a small compressor will work okay with the leak down tester.
I'm pretty sure I already have a compression tester.. not sure about he leak-down tester.. but I'm sure HF has one of those for cheap enough.
