I have an Onan Emerald 4000 generator. The Wix oil filter is part number 51374, which is 3.5" long. I would like a longer filter so it is easier to install/remove, as it is hard to access.
The 51374 lists 385 psi burst and 25 nominal micron.
Another common Onan generator filter is the Wix 51762, which is 4.5" long. However, it has only a 200 psi burst (all other specs the same, but for minor variance in gasket).
Or I can get Wix 51516 (cross refs to Motorcraft FL400a). The Wix 51516 has a 275 psi burst and 20 micron.
I am inclined to get the higher burst , though 200 psi is probably good enough, but is the 20 microns of the 51516 okay if the spec filter says 25 microns?
Do the burst strengths vary for the same application between different manufacturers? I wonder what the burst strenght is for the Onan versions of 51374 and 51672. Seems odd they would spec a 385 burst for the smaller generator (4000 watt) and a 200 psi burst for the larger generator (6000 watt).
Anybody have suggestions for a different filter number that may be even better? I have plenty of clearance for 1 to 1.5 inches longer filter, but little to no tolerance for anything wider.
Here are the full specs for the specified Wix 51374:
Ht: 3.529"
Dia: 2.996"
Thread: 3/4-16
Bypass: 8-11 psi
Antidrainback: Yes
Burst: 385 psi
Gallons/minute: 7-9
Nominal Microns: 25
Gasket OD: 2.74"
Gasket ID: 2.37"
Gasket thickness: 0.275"
This filter does fit several automobile applications (I think all import), so should be available at most parts stores or NAPA.
BTW, who makes oil filters for Onan?
Ht: 3.529"
Dia: 2.996"
Thread: 3/4-16
Bypass: 8-11 psi
Antidrainback: Yes
Burst: 385 psi
Gallons/minute: 7-9
Nominal Microns: 25
Gasket OD: 2.74"
Gasket ID: 2.37"
