It's a great way to go and I know folks who track their MK7 VWs that have them. It has some downsides as well for a street-driven car namely length of time to get it up to temp (can be manages better with a thermostat), additional complication to the system (leaks etc.), more challenging and messy drains (if you want to drain it and the lines), and install (some can be laborious).I'd install an oil cooler
I use a water oil cooler on my car. Works really nice and dropped oil temp 50 degrees.It's a great way to go and I know folks who track their MK7 VWs that have them. It has some downsides as well for a street-driven car namely length of time to get it up to temp (can be manages better with a thermostat), additional complication to the system (leaks etc.), more challenging and messy drains (if you want to drain it and the lines), and install (some can be laborious).
There are two types...sandwich plate style that is easy to install but creates v. messy changes due to the filter setup. Also uses smaller filters to clear the hood. Some use a reusable metal-media filter that had lower filtering efficiency. Finally these maintain the factory heat exchanger. Easy to install is a plus. The other is the plate style that replaces the factory heat exchanger on the back side of the filter housing. These divorce the cooling system and oil which is the most efficient for low oil temps but will warm up the oil the slowest. These are more complicated to install.
The placement of the core is critical and can require some ducting to not have an adverse impact on intake air temps out of the charge cooler (intercooler) which somewhat negates the value of doing an oil cooler in the first place - being able to stay hammer down for longer.
I'm not there yet. Most of the track events I do are in spring/fall so cooler ambient temps which helps. If I can send it for 20 min without overheating the car on the factory system it's a hard justification to me as the primary reason to do it is being able to go longer. The ECU tune is part of the equation (lower boost and more timing advance is better for overall temps) as is air flow (hood vents). If you look at the MK7 TCR race cars they don't run an external oil cooler.
This is an excellent resource for VW MK7 cooling information that is tested...a buddy of mine:
https://search.app?link=https://www..._campaign=aga&utm_source=agsadl1,sh/x/gs/m2/4
Mine already has one...the OEM setup is this way.I use a water oil cooler on my car. Works really nice and dropped oil temp 50 degrees.
Plus the oil heats up faster.
Of course your cooling system has to be capable to handle the heat.
I got mine from a stock car team that retired the car. It's big.Mine already has one...the OEM setup is this way.
Nice. The OEM VW one is small. Best on my platform to just add a traditional oil/air cooler like I mentioned above. If this ever turned into a track car that's what I'd do but I'm holding off as long as I can.Here's is what mine looks like. It has a thermostat installed too. Keeps my oil temp rock solid at 220F
So you've had bad oil color and oil-related engine sound in the past, not changed the oil per your usual metrics and kept it in and then had engine issues before to verify these metrics?but color and knowing how the engine sounds is my never fail me go to.
0w20 premium PCMO. The wifes new car has the premium plus in the same weight.There are several HPLs. Which one have you run the past 6k?
Never any engine issues. Just a personal thing.So you've had bad oil color and oil-related engine sound in the past, not changed the oil per your usual metrics and kept it in and then had engine issues before to verify these metrics
Ok, so "it's my never fail me go to" is just personal/not based on anything more. It doesn't fail you b/c you've never actually done anything else. The HPL is good for 10K...it's an Altima...Never any engine issues. Just a personal thing.
Working on it.My view of long term use of an oil is 10K OCIs for at least 200K.
I started using M1 oils in 1978 at 10K OCIs in many different Ford engines.Working on it.
Currently on my 5th fill of HPL products at 10-12k OCIs
You are dumping premium and premium plus at 6k?!?!0w20 premium PCMO. The wifes new car has the premium plus in the same weight.
