A few things here:SuperTech is low budget oil. It's meant to sell for cheap, so it's made cheap. Someone makes it for Walmart, but I can't recall who. The manufacturer has to make a profit, Walmart has to make the most profit, and the customer gets it for what, $15? It's not hard to see how cheap oil that barely qulifies as synthetic can sludge up. Add to that the $15 or $16 you spend for each bottle of additive, and you are not making any progress. For the same money you can get Mobil 1 Extended Performance 5W-20 and for another $8 a Fram Ultra oil filter which is one of the best in the industry. Mobil 1 makes the best motor oil in my opinion, as they made synthetic oil mainstream. Just a thought. At the end of the day you should do as you wish as it is your vehicle and money to spend. I'm just giving you my two cents because I found this discussion very interesting.
1) Supertech is a budget oil made my Warren Oil Company which makes a number of store-brand oils (including Kirkland/Costco and Amazon Basics) and is well regarded for making quality products. Their oil is well liked on BITOG and backed by lots of used oil analysis/users. I use it in 2 of my vehicles.
2) Substantiate "barely qualifies as synthetic".
3) The "sludge" in the OP's pics is simply MoS2 and oil mixed and some oil is always left over after a drain. Folks getting worked up about nothing.
Glad you are happy with M1, it's a fine oil that I've used it quite a lot over the years. If you used MoS2 with M1 (name your flavor) the result would be 100% the same - some oil with a shimmery appearance from the solids in the MoS2 additive left over here and there.
