The potential of hemi lifter/cam issues has me concerned. I had bought a 6 pack of MoS2 and one of Lubeguard biotech when I found mail-order deals on them and got too click happy.
For what its worth (and both additives have posts here showing fallout), LM recommends their Ceratec additive in modern engines and MOS2 in older engines.
That has been my reasoning using the MSo2. I use it in good old simple pushrod engines.
No additive is going to prevent failure if one of the rollers stops rolling. Keeping the oil clean and those needle bearings free of contamination is, IMHO, the best possible thing you can do for them.The potential of hemi lifter/cam issues has me concerned. I had bought a 6 pack of MoS2 and one of Lubeguard biotech when I found mail-order deals on them and got too click happy.
True - but they also at times if you follow their stuff online say that MoS2 can be alternated with Ceratec between applications - per LM, the Ceratec is a 30K(maybe 20...can't recall now) additive and contains both a chemical and solid friction modifier additive. So after the first change with Ceratec, you loose the solids and you can use MoS2 for that.For what its worth (and both additives have posts here showing fallout), LM recommends their Ceratec additive in modern engines and MOS2 in older engines.
I understand your reasoning, because I know people have floated moly as a panacea, but moly hasn't prevented the failure on the SRT's, for which the 0w-40 has a pretty large slug of, and I recall some of the "redline" guys, with its very high dosage rate also experiencing it. Moly is more of an FM than AW additive like ZDDP. The oil I'm using in my SRT has no moly at all in it, they use a tungsten FM in its place.I'm with you, but no one really knows why these rollers stop rolling in the first place. There's several theories and more hemi tick threads than you could or would want to read. It seems like most who've posted their experiences with hemi tick or needed thousands of $ worth of engine work because of it followed a regular oil change regimen as well. My thoughts on these additives was to increase moly levels in the oil.
I took more pics of the filter can today after it sat in my drain pan all night. The thick black stuff did work it's way out. This may be a concern about nothing.. I did no wiping of the inside of the can.
There is a simple solution to eliminate after market additives sediments but, who knows...Apparently no concerns about using after market additives after this experience?
The vehicle as 20K miles? What are you trying to accomplish?
Looks like oil containing mos2 to me? I'm not sure what else you expected to find in the oil filter? next time mix the qdditive in an oil container and see what it looks like fully mixed. I bet it looks exactly like the oil in the filter.
What I did was mix mine and let it set overnight. The oil was dark and it did not separate.
I wonder how long MoS2 takes to settle? My unscientific test of premixing it in the oil the day before showed it was still fully mixed and no sediment in the bottle after it was poured. Years ago I would just pour it straight into the motor. That cut open filter after running MoS2 is interesting. I have never cut open a filter before. Since becoming an injured "posting member" here I have a lot of time on my hands. So I'll start cutting them open and checking.
I did the physics-based calculations a few years ago, here:
https://www.bobistheoilguy.com/forums/threads/small-particle-mos2-settling-time.163225/
