Liqui Moly MoS2 interesting sediment pics.
Can this oil be used in a street vehicle? It looks very appealing for a small 4 banger turbo.
Here's the page for it:
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-racing-0w-30
They state:
Mobil said:
Mobil 1 Racing™ 0w30 is developed specifically for racing engines and is not recommended for street use. This high performance, fully synthetic formula is specially balanced for friction reduction and optimum horsepower with outstanding wear protection.
Mobil 1 Racing 0w30 is designed for use by professional, amateur and weekend racers.
With more than 30 years of experience and race-winning performance expertise, ExxonMobil has developed Mobil 1 Racing™ oils for premier automotive racing series around the world, including NASCAR, Formula One Grand Prix racing, and the Porsche Mobil 1 Supercup to name a few.
For road and track use, consider Mobil 1™ motor oils available in the 15W-50 or FS 0W-40 viscosities.
So it doesn't seem like they recommend running it in a street-driven engine.
I see this thread has gone all over the map in true bitog fashion. I'd have it no other way. :D
I'm just shy of 37K miles on the truck now, so I've done 3 additional OCIs since creating this thread. I do my OCIs every ~5K miles regardless of what the OLM says. It's usually at ~50% life remaining. I did one with Lubeguard biotech, one with another bottle of MoS2 and the the latest OCI was with the new ultra high quality "20K mile" Supertech synthetic 5w30. In went 7qts of that and nothing else. Still using Champ PH48 filters. I've got a bunch of the filters left and probably 4-5 bottles each of MoS2 and LG biotech which I will continue to use.
As you'd expect, the oil drains out darkest when MoS2 is in use. Nothing sludge-like. Just dark. Truck runs like a dream. No ticks, taps, or undue noises.
It runs like a dream because you have a healthy engine. It has nothing to do with the goop you put in there. Just use a good oil and get rid of the Snake Oil. Pennzoil Ultra Platinum and Rotella Gas Truck are excellent choices for your engine, and cheaper than oil+goop. The owner manual for most vehicles states that adding anything to the oil will void the warranty. I'm sure that the slime-looking oil will stand out if you're ever towed into the dealership.
They can't recommend any non-API oil
KIA K5 GT - 2.5 Turbo - would you run it? It calls for 0W-30.
That said, the question remains, does running this racing oil give you any advantage?
Mobil 1 claims reduced wear and improved friction reduction. I don't know how much improvement I could see in practice.
  • Haha
Reactions: JTK
You make a lot of presumptions.
I was never here to promote the product. Just sharing my experiences.
Like what?
What do you have to share other than info you've essentially cut and pasted from other sources?
Again, the intent of the thread from post #1 was to share what I saw, not promote or recommend any product.
I'm no expert, but have been active here since 2003 and have shared many actual experiences. What do you have to offer?
Can you provide any factual data that supports the claims that these oil additives actually do anything? Long term testing, followed by engine tear downs, or laboratory testing maybe? You chose to share your experience and receive opinions. You got mine, which is that engine oil additives are Snake Oil. A fully formulated oil should perform within its predefined parameters without any help. Altering its chemistry will produce unpredictable and sometimes unwanted results. Do the manufacturers of these additives provide any factual evidence beyond anecdotes that their additives are nothing more than a waste of money? Did they perform any meaningful and long term tests that can show their benefits?
Sounds like a BITOG experiment in the making!
I would be willing to give it a shot if I could somehow be certain that it won't result in anything bad happening to my engine.
Just my guess, someone more interested could call or email Mobil.
No need to call Mobil. This comment answers what Mobil would say:
Plus as Jetronic already noted, ExxonMobil isn't going to recommend an oil for street use that has zero licenses or specifications.
This is true, and they won't recommend using 5W30 in a 5W20 application or vice versa, even thought it is done everyday. They have a legal department dictating what they can and can't say.
They will recommend 0W alongside 5W motor oils. I guess that makes sense. Still, I have found their recommendations do be generous when compared to some of the other oil producers.
