Originally Posted by SnowDrifter
Pac is the way to go
That being said, if you do this, you're risking introducing equalizers, high pass filters, as well as any additional noise that may come from the stock stereo
If you really want to get fancy, RF360.3
My 2 cents... Put in an aftermarket deck. There's a lot to be gained from swapping out an 8 year old stock radio
In my previous Escape, a 2008, that didn't come with Bluetooth or steering wheel controls, I installed an aftermarket head unit with no trouble - it went just fine just like the other more than a dozen stereo installs I've done. HOWEVER, on my 2010 Escape, I lose Ford Sync and steering wheel controls unless I buy some expensive module, and the line output converter is actually cheaper than that module - and that's not even including the cost of the head unit itself.
