Originally Posted by Mad_Hatter
Originally Posted by John344
I was thinking that it's a dry engine until the pump send the oil to the engine parts because if you notice in the other video inside the car, the sound went off after the oil icon in the gauge cluster went off.
With your ambient air temps and you using a 5w40 it ain't gonna take but a few seconds to get the blood flowing. And correct me if I'm wrong, you should have a residual film of oil on the metal parts even if it's been sitting for hours. I think this is where using a quality oil with a good anti wear pkg comes into play. Those elements provide a sacrificial layer between the metal parts in those few seconds it takes to get the blood flowing throughout the engine. I'm sure the oil gurus will find something to correct in that, but I think the basic idea is true. ...
It is true, oil is supposed to "stick" to the moving parts/oiled sections of the rotating assembly for residual something to be on the moving parts until the oil pumps it back up, which on a hot start is within a second or faster and on a cold morning is usually very fast if using a nice thin oil with very good cold flow properties.
I remember reading somewhere that a Group 5 oil had the best properties of sticking to the parts..
Group 4 had the worst cold-flow properties..
And Group 3 has become very, very good, leading to questions on whether boutique Group 4 or 5 oils are worth it.
I would think that gravity would drain all the oil down eventually, there may be some things in the oil that make it sit on the oiled sections so it is not a dry start.
And "tick tick tick" sometimes called typewriter sound on start up they call that Lifter Tick, it is so common.
