Snagglefoot
Thread starter
I did replace two rubber hangers that deteriorated after 15 years. They had metal straps inside and the rubber ripped, and the metal rusted apart.
Painful to recall. 2010 my ‘98 Maxima exhaust rusted out. Midas fixed it cat back. Mgr wrote “lifetime guarantee entire exhaust” and stapled his business card. When it failed again they wanted $800. I said nope lifetime and corporate which was sold and moved from Chicago to Miami said nope, he had no authority to say lifetime on entire exhaust. Went to BBB and they said they’ll do it one time. So when it failed 2 years later I had to pay for all but the muffler. After that had wife’s uncle do it.As I recall all Midas mufflers were also gold annodized......LOL.
From what I've read after leaded gas was phased out exhaust systems started last much longer. Add stainless steel and rust resistant alloys and I'm surprised that there are as many muffler shops still around.I recall when replacing a muffler or section of exhaust system was an expected maintenance item. My 16 year old Burb still has its original exhaust system. It got so bad that Midas Muffler had to morph into a tire store. Anyone else finding that?![]()
Since when was leaded gasoline phased out? j/k I bet there are many here among us, who never owned a vehicle that used it.From what I've read after leaded gas was phased out exhaust systems started last much longer. Add stainless steel and rust resistant alloys and I'm surprised that there are as many muffler shops still around.
Why do they still call it unleaded? It’s like drinking uncreamed coffee.Since when was leaded gasoline phased out? j/k I bet there are many here among us, who never owned a vehicle that used it.
I drilled drain holes in my Honda Accords dual mufflers- they faithfully leaves puddles wherever parked.A lot of exhaust failures for people who do short trips there's too much condensation trapped in the pipes and they rest from the inside out. I know I tell a lot of people if you can get some Grill paint high temperature and be able to coat the factory piping and let it sit for a couple days it will help but if you live somewhere where they salt and you don't have at the very least 409 Steel or better you're in for a big hurt real quick
My wife’s Buick Enclave has holes from the factory and there are puddles under them when I go on a short trip. Also black soot around them.I drilled drain holes in my Honda Accords dual mufflers- they faithfully leaves puddles wherever parked.
Probably just stuck as it had been called unleaded for so long. Most cell phones still use the icon for a tape for voicemail. Most people probably haven't had physical tape in an answering machine in what 15 years?Why do they still call it unleaded? It’s like drinking uncreamed coffee.
My (mechanic) uncle always did that too. A small hole at the lowest point - which was usually/always at the back.I drilled drain holes in my Honda Accords dual mufflers- they faithfully leaves puddles wherever parked.
Supposedly if you do a lot of short tripping where the water never burns out then it can rust early.My 1993 Nissan (built in mid 92) went to its grave with its original exhaust system intact, 30 years old and over 400k miles. That car saw all sorts of salt over the years. All the cars I owned when I started driving in the early 80's had multiple exhausts over their lifetimes.
Many more exhausts lasting longer than they did in decades past, I think we can probably attribute a lot of that not only to more OEM's using stainless pipes and mufflers, but also to only having unleaded fuels now, as well as the decrease in sulfur in todays gas. Leaded fuels had perchloroethylene, bromine, and whatever else to help prevent lead deposits, but those same additives had a nasty habit of combining with the water in the exhaust to produce acids and the pipes got eaten from the inside out.
