Lexus Sealed Transmission
Kennett Square, PA
Been watching DIY videos on ATF drain/fill on sealed transmission. When drain plug is removed on cold engine, a fair amount of fluid comes out, much more than would be captured in overflow tube. How can this be because level should be below overflow tube on a cold transmission? Curious that nobody mentions why this happens. Thanks.
I think, I think, it is bcs. drain plug is at the lowest place in the pan, and the overflow tube is not.
If this is not clear, give someone else to do a fluid change.
Good question. I don’t have the answer, but I want to clear up some confusion.
The drain plug, and overflow tube are in the same location. You must remove the drain plug to access the overflow tube. I couldn’t really find a picture to show this, but the video sort of does starting at 1:25
The fluid level should be below the tube when the engine/transmission are cold .. yet, more fluid than the tube holds, drains out when you remove the drain plug. How? Not sure. I just did a drain and fill on my ‘21 rav4, and experienced the same. For my rav, Toyotas adjustment range is 95f-113f, and I’m pretty sure my scan tool said the fluid was 77f when I started draining too (for the initial drain, not for adjustment. I started adjustment at 96f)
IIRC, isn't the engine running during checking of fluid? If there is a loop in the radiator, it might be now full, as is the rest of the transmission. But when draining, it's not running, most of the fluid has drained to the pan. Much less to do with fluid expansion and everything to do with running/not running.
But it's been a while since I dealt with the sealed trans on my Tundra (my Corolla I just add what I took out and have not verified level, don't remember the procedure).
The passages or cooler or other places the fluid is pumped are draining down into the pan.
For example, when I drain and fill my 6R80, i pump fluid back until it comes out the fill hole, then start the engine and add another ~2 quarts of fluid. When it gets to temperature it sits right at the cold/hot full line on the tiny dipstick in the fill hole.
I think this is the answer. Car is not running when you drain old ATF so sump probably has extra volume drained from the system. This makes sense when you consider you must cycle through gears to “load” system before duetting final level.
Not sure I understand your question. "Captured in the overflow tube"? What does that mean? Fluid sits in the pan when cold and not circulating.
Follow trans service procedure and you will be fine. Generally about 2.5 to 3 quarts is replaced unless you do a cooler line service.
I will say it is a dumb process. Shouldn't be so involved and error prone.
After trans reaches normal operating temp, sump level is above top of overflow tube and overflow tube fills with ATF. When trans cools down, sump level drops below top of overflow tube (premise of my question) leaving a small volume of ATF captured. That is the volume I was talking about. But, as we now understand, sump level probably is always above top of overflow tube because ATF drains into sump when car is not running.
I understand procedure…was just curious about the issue extra volume which drains from overflow pipe.
In many cases the converter isn't completely full when the vehicle is off.
In some rare cases like the Dodge 46RE you've gotta check in N because it doesn't fill the converter in P. Granted, those have a dipstick but the point is the state of the converter drastically affects fluid level in the pan.
