The last drop to fall should be the most contaminated. Once the flow from the drain becomes a trickle I let it drain for another 30 minutes.
How so? Please explain. Also curious, even if true, how would the concentrated contamination of the last few drops matter, when compared to the contamination of the massive volume already drained?
I hear tell M1 works better...
Do I detect a little bit of sarcasm, towards the BITOG community's latest choice for motor oil worship?
p.s. I'm with you on the oil extractor method, but I can't use mine on my wife's Outback. Too small of a dip stick tube.
After reading a few other discussions on this, one of the favorite subjects here on BITOG, I did a small amount of research. According the Subaru service manual, I found the 2.5 liter engine in my wife's Outback retains about 0.9 quarts (0.85 liter) after full drain. The 5.5 liter engine in the MB SL550 that I used to drive held about 1.7 quarts (1.61 liters) after full drain.
Let's use the 50 ml difference between quick and extended drain, that
@Owen Lucas measured in his experiment, as no one else has reported carefully measuring it. So if we use 50 ml as the extra oil that is drained in an overnight drain, that 50 ml is about 5.6% of what remains in the Outback's 2.5 liter engine, which is a very common engine size in today's cars. In the larger 5.5 liter engine, the 50 ml is only 3% of what remains.
I'm a guy that loves data, so based upon this data, I have stayed with the practice of waiting until the drips are a few seconds apart, close the Fumoto valve, and fill her back up with oil.
