I mean, it lowers the viscosity a bit allowing the oil to flow out better amirite?Forgot about that![]()
I let mine drain for at least a week. Seriously….why not figure out a way to flip the car over and get every last drop out
Do the KISS method..... Keep It Simple Stupid.....Or just start it up and let it run for 5 or 10 minutes to pump the last of the oil out
Call me lazy I guess.
I pull the drain plug out, remove dipstick and oil fill cap, remove the filter, replace filter, reinstall drain plug, and fill it up with new oil.
Start to finish is less than 15 minutes.
I'm not draining it for hours, or days.
Within 3 minutes its barely dripping.
Thanks for the input, first time I’ve heard of that. Do you remember what kind of car/engine?Had a customers car on jack stands to perform front end work, also to change oil and filter. Removed drain plug let drain over week end. Replaced filter and drain plug, added 5 qts oil, started engine no oil pressure. Pump would not pick up oil. Removed oil sender forced oil down to pump. Started engine, pump pick up oil pressure, what a relief. Be careful with extended drain time!
I've tried the extractor, and pulling the drain plug gets more oil out, in all three of my vehicles. An extractor leaves me with a few questions. For example in this post people are concerned with getting as much oil out as possible, draining oil overnight so they can get every possible drop out. Oil can take several hours to drain from high places in the engine and get to the pan. Two beers and an extractor isn't getting that oil out. I've extracted oil, couldn't get another drop in the extractor, then I pulled the drain plug and got more oil out, leaving it out for half an hour. That might have put me to beer #3, etc, the longer I let it drip. Granted I didn't get much oil, only a couple of ounces at most but for the purpose of this thread the extractor imo falls short.
Having said that how much longer will an engine last allowing oil to drain into a collection pan overnight? My bet, not much with sane OCIs. I recall reading about people starting their engine with the drain plug out to try and get more oil out, others pouring fresh clean oil through the engine to do some extra cleaning on the way down to the pan. No comment on either of those practices. At some point the OCD has to stop.
Regarding the extractor it is a great tool, and on certain vehicles an asset for changing oil. My drain plugs are easy to access, and two of my three vehicles I have to get under to get the filter. So it sits in a box until I do a transmission service, or something else requiring it. It earns it's keep pre-draining ATF making pan drops much easier.
I run a quart of the cheapest 10 weight I can find to flush the bottom of the oil pan..
I think they call it Canola!Where do you find 10 grade oil?
White GOLF. And a GD wagon too that has some big, angry gonads.How would you know?? Stop lying to these people. Let's analyze this.
White Jetta....check.
Gotta put the kids somewhere.Roof rack....check.
Well...........Liqui Moly products....check.
With a healthy shot of Tequila.You KNOW you're a mimosa and cosmopolitan type of guy.
Gucci? How passe. LV. And it's a clutch. Something to keep in the hand while he beats some a$$ with it.You're a Gucci purse away from being a basic white gi....lemme stop.
