When your lawnmower demands the best.
It won’t hurt a thing. The next oil change that I do on my mower will get a mix of leftover Frankenblend and Rotellata T5 15W40. The Frankenblend is around a 9W35. The mower will get 1 liter of each.I accidentally put the half liter of Castrol 0W-30 oil that I was keeping for the next oil change on my BMW in the mower. I guess it'll do the job.
what?You buy your oil by the meter?
Of these, I would use the Rotella 15w40 (unless the OM specifies a different weight, in which case I would use the specified weight).I'm wondering what the "best" oils would be for a hardworking lawn mower would be. I would like an oil that I can buy at Walmart. I change oil every other month.
I'm not trying to start a war. Just looking to learn some information.
A synthetic 10w30
Rotella T6 15w40
Rotella t6 5w40
Mobil 15w50
Euro 5w40
Euro 0w40
No an hour meter shows the hours in use for lawnmowers, snowblowers etc.You buy your oil by the meter?
You better slap a M badge on the mower deck, failure to do so may result in the engine blowing up prematurely.I accidentally put the half liter of Castrol 0W-30 oil that I was keeping for the next oil change on my BMW in the mower. I guess it'll do the job.
I never have had an oil consumpiton problem. This mower is about 10 years old. I bought it used a few years ago. I switched to 10w30 synthetic this year. I changed it last november before I put it away for the season. Incluiding the oil change and a slight top off. I have used 16 ounces of oil since I changed it last November. I plan on changing the oil soon.I was given a mower with a perceived oil use problem. When I first checked it it was just about empty. I did some clean up to the carb and blade, oiled the cables adjusted wheel height and that sort of stuff. I filled it up with oil from the oil drain can to see if it smoked, no smoke I could see after 10 minutes of running. So I drained that stuff out and replaced with rotella t 15/40. It ran smooth and quiet for all of last year , with no oil needing to be added. And this year it has been used about 6 times, still with no oil needing to be added. My opinion is that if your having to add oil during the mowing season, even if your using the recommended straight 30 wt, bump it up until you don't need to ad additional oil during usage. Temps where you mow, height of grass, hours of use effect how hard the mower is working so oil is not a one grade fits all situation.,,,
