I'll agree with the Avalon. Really liked the last one
Look at the CarFax. And yes, money is money. Cars are depreciating assetsDoes that make sense buying a used base 2WD with seventy thousand Michigan miles on the clock against a new one for $39k? I get that money’s money, but I would do what I could to swing the $15k. The warranty, new tires, certainty the car has not been abused and the new car smell has to have some economic value. My thought is that the price right now is so good, it has to be considered.
Dang! That's WAY too nice for a kid that has a 50/50 chance of rubbing it up against something or running it into something in her first year of driving. Buy her a pre-dented minivan and remove all the back seats. She'll learn humility and be safe(r) at the same time.
Your OP sounded like you were asking about buying a replacement but that you were open to buying another vehicle in the meantime. Perhaps, I'm mistaken. But that is a better approach IMO. Your budget should allow for something decent & last you a long time. I don't think you can go wrong with a Toyota product, although I've never owned one. That Mazda I pointed out has some good safety ratings.It's only 1 purchase
In about 8 months, daughter will get her license and receive my Altima. I will be in need of a vehicle for myself. I'd like to find something 15-19k dollars that will be reliable. Seems nothing is really made that well anymore. I like leather seats and nice looks. I am open to a FWD CUV mid-sized or a sedan. I am leaning towards a used Lexus ES350 at the moment. What other recommendations do you people have? What about a Charger/300? Too much of a gamble?
All true, and I am glad that you are looking at the Pathfinder. But I would ask you to consider that when you add up the value of a warranty from a manufacturer, the likelihood of immediate or soon to happen tire replacement, any other wear and maintenance items, and the depreciated physical condition of the car, etc. etc., you are paying a very small premium for the new model. Again, generally speaking you are absolutely spot on that you can benefit from the immediate rapid depreciation on a new car, but in this case, the cash on the hood, the number of these things in inventory really make a case for this particular sled. Of course, that's not the case for, say, a Honda Passport, which gets close to list and might be another ten or fifteen K over the cost of the new Pathfinder. I am one of the biggest penny-pinchers there is, and will not buy anything that I don't perceive as a good deal... so....Look at the CarFax. And yes, money is money. Cars are depreciating assets
Daughter gets my ride, I get something newYour OP sounded like you were asking about buying a replacement but that you were open to buying another vehicle in the meantime. Perhaps, I'm mistaken. But that is a better approach IMO. Your budget should allow for something decent & last you a long time. I don't think you can go wrong with a Toyota product, although I've never owned one. That Mazda I pointed out has some good safety ratings.
The 9T65 is an awful transmission. GM has no idea what they're doing and they don't give a rat's behind about their customers either.An upper-level mid-size Buick SUV…the Envision Avenir…lots of them out there, should be able to get a good deal. With 2.0 Turbo, they are peppy and reliable.
???view 70K as very high mileage for this car...
The early ones had TC shudder problems. Many leading to TC replacement, but there's lots of high mileage 2018-2023 Traverses out there without issue. The nice thing about the 9T65E is, they're as easy as an engine oil change to spill and fill the ATF on them.The 9T65 is an awful transmission. GM has no idea what they're doing and they don't give a rat's behind about their customers either.
I've read a ton of horror stories online about nearly all of them needing a rebuild by 100k.The early ones had TC shudder problems. Many leading to TC replacement, but there's lots of high mileage 2018-2023 Traverses out there without issue. The nice thing about the 9T65E is, they're as easy as an engine oil change to spill and fill the ATF on them.
The first video says 2018-2025 and is lumping the Acadia in the mix that uses a slightly different 9T65. The last year for the 9T65E in the Traverse was 2023. Like said, the 2018-2019 were notorious for the TC shudder. Beyond that, not so much. The Acadia used the push button E-shift version of the 9T65E which is not a great unit in that nearly all the problems with it are associated with that E-shift system. The GMC Terrain used an E-shift verison of the 9T45 that is also problematic.
Hmmm. Okay, I'll consider a low mileage FWD Buick Enclave Avenir then.The first video says 2018-2025 and is lumping the Acadia in the mix that uses a slightly different 9T65. The last year for the 9T65E in the Traverse was 2023. Like said, the 2018-2019 were notorious for the TC shudder. Beyond that, not so much. The Acadia used the push button E-shift version of the 9T65E which is not a great unit in that nearly all the problems with it are associated with that E-shift system. The GMC Terrain used an E-shift verison of the 9T45 that is also problematic.
The 2020-23 cable shift 9T65 is not too bad for something made by the general.
I'd avoid a used top trim level Buick like this, just due to all the GM electronics & modules on it.Hmmm. Okay, I'll consider a low mileage FWD Buick Enclave Avenir then.
Don't need AWD, don't want it either. A 3 series is too small.A mazda 3 or mazda 6 (both have FWD, 2.5 liter 4 banger, +/- 185 HP, more than adequate of power for merging, passing, etc. Great gas mileage, Mazda's well known handling, above average interior materials, good mechanical history and reliability and most importantly great bang for the buck. If you need an AWD, you can't go wrong with a CX5.
