Leave the oven door open after use in winter?
Suburban Washington DC
To help heat the house, or doesn't it matter? Keeping it closed and the heat is still contained in the house but released slower, vs. having it open and the heat is released faster. Logic suggests better to leave open, but I'm not a thermodynamics engineer.
I used to do the same thing, but realized that having the oven on only warms up the room closest to the oven. It still using gas if you do it for an hour or more, so why not just turn the heat on and warm the entire house?.,,
I assumed he was talking about after use and the oven turned off . Just taking advantage of the residual heat .
I used to leave it open but now whichever way. Doesn't matter unless you want to warm the room right away.
Either way nothing is going to waste except if leaving the oven open warms a small home or apartment higher than the thermostat setting, then leaving it open is wasting heat so you would be better off with a slow release.
