Least Expensive Scan Tool with TPMS Capabilities
CA
It appears as though I'll need to spend some serious $$$ if I want a scan tool that has true bi-directional capabilities. Since I won't be using the scan tool that often, it doesn't make much sense for me to spend $1500 or more on an OTC Genisys or a similar product.
Therefore, my new goal is to find a scan tool that will allow me to read generic OBDII codes, ABS codes and reprogram TPMS sensors. What's the least expensive tool that will allow me to do all of those things?
Thanks.
I have not seen integrated reader with TPMS capability. Autel makes scanner which has ABS and airbag along with OBD-II but I found too many bugs with my unit.
I doubt if you can find what you are looking for under $1000
- Vikas
