The oil pan's drain hole - Victory motorcycle - had stripped threads. Victory (and maybe Indian too) motorcycles are known for this problem. A Time-Sert M12 X 1.50 Drain Plug Repair Kit was installed using Red Loctite on the insert's outer threads. Put oil into the motor and it leaked. I'll try Loctitte PST sealant to temporarily stop/slow the leak but it will need a permanent fix.
Anyone removed a Time-Sert that's been thread locked with Red Loctite? If I can get it out, then what?
If worse turns to worst, it's possible to epoxy the leaking plug into the pan and make a new drain hole. But I want to avoid that. I think the best fix would be to remove the current Sert and install a new one (without leaks, of course), if possible. Thoughts?
