2011 f150 5.0
Changed the oil a few months back and for some time the old plug would always be a little tougher to remove the first few turns then come out, going back in kinda the same. Well a few months ago I pulled the plug out and the threads on the plug were sharp. Obviously it was bad. I couldn't tell 100 percent if the pan was messed up or not (couldn't get the best look but looked ok at least as far as I could see). Got a new plug and it went in just fine all the way. Well changed it tonight before work and it came loose VERY easy. Like it wasn't tight. Wasn't leaking but I was surprised. It could POSSIBLY be because it's the kind with the rubber built into the underside of the head and it was new and just compressed some... took out, Same thing as the old one, except a little tighter. First few turns tight then loose, going in loose then tight the last few. The plug itself looked good. Was running late to work so for some dammed reason I didn't even think of looking at the pan. So I'm going to leave it be for now, but come up the next oil change I'm going to take a close look at everything. Is this a sign of stripped or galled threads in the pan? If so what would be the best fix without removing the pan? I see oversized drain plugs, the kits with the drill, tap and heli-coil, etc... what do you guys recommend? I mean it's holding oil, just want to be prepared if next time is the last time for it
