Here's a trick I recently came up with to save my fingers from the hot drain plug and hot oil. I tear a 1/4" strip of cardboard from the filter box and fold it over the edge of a deep-well socket and push it onto the plug. After breaking the plug loose, remove the ratchet, and remove the plug and socket
together by hand. This will hold the plug in the socket while removing, protecting your fingers and hopefully keep you from dropping it into pan.
